Nvidia GeForce GTX Titan X 12GB Overclocking Results
Our GTX Titan X wasn't quite able to surpass the claimed 1.4GHz boost speeds when overclocking, but we weren't far off. Using the maximum power and temperature targets (110 percent and 91°C respectively), we added 190MHz to the base clock, taking it to 1,192MHz (1,266MHz boost). At this speed, it was boosting to a constant 1,341MHz under load (1,366MHz maximum), which is 18 percent higher than we observed at stock speeds. We did manage to get through a few benchmarks at even higher speeds, but in others the card crashed, so we dialled it down. Still, it's a very commendable result, especially for such a high power GPU.
The memory settled at around 8GHz effective, a very nice 14 percent boost. This is the first time we've dealt with SK Hynix's 7GHz memory chips, as all 900 series cards we've seen have used Samsung ones, and it's good to see that they overclock just as well. At 8.1GHz, the card was still benchmark stable, but with artifacts showing we dropped it back down a notch. The results of our efforts are below:
        AMD Radeon R9 295X2 8GB
        Nvidia GeForce GTX Titan X 12GB (OC)
        Nvidia GeForce GTX 980 4GB
        AMD Radeon R9 290X 4GB
Frames Per Second
        Nvidia GeForce GTX Titan Black 6GB
        Nvidia GeForce GTX 780 Ti 3GB
Frames Per Second
        Nvidia GeForce GTX 980 4GB (OC)
        MSI GTX 970 Gaming 4G 4GB (factory overclocked)
        Nvidia GeForce GTX 780 3GB
          2000
          3000
          4000
          5000
    Score (higher is beter)
